There seems to be a ECU here if it is the right one.
Your part of the country too.
MK1 and MK3 VR6 parts - some free
Have attempted to solder a performance chip in, and now won't start. Even with the factory when i put it back in.
It feels to me like the immobiliser is cutting the engine.
Any ideas?
James
Sorry let me try that link again.
Hey if it doesn't work look I'm the parts for sale.
Just read the tread again, wrong ECU for you![]()
258bk? I've got one.
If it's the same ECU it can't be the immobiliser mate.
You should buy a big magnifying glass and examine all your soldering. Even go to the trouble of continuity checks of each joint to the next point on the board if you can.
What method did you use for removing the chip? Hot air is the only sensible way to do it, you get all the legs at once.
ive got one up in Launnie mate.
unsure if its OBDI or II though, ill have a check.
let me know if you need it
