Results 1 to 10 of 12
Thread: WTB Mk1 Sway bars/Strut braces
    Oct 2014
    Hi guys,
    Looking for anyone in aus that has or can make front upper or lower sway bars for my manual mk1.
    Cheers.
    Feb 2009
    Please Enter Location
    Whats an upper sway bar ??
    Upper and lower front brace - you should be able to make both for $20. Real easy to do and the lower one makes a big difference to the handling. Go to build thread :) and see my post on how to make them and what good they do.
    Rear swaybar - you can do for less than $60 and a few hours welding the brackets onto the Golf. Biggest cost is getting a thick front bar off a Jap car that fits the Golf from the wreckers. On mine I used a bar from a Mazda Capella on one of my MK1's and a Sigma on another MK1 (it was a long, long time ago). Front sway bar isn't needed (even the aftermarket ones are quite thin), it's the rear one that does all the work.
    Paul
    build thread :)
    Oct 2014
    I don't have the knowledge or equipment or garage to do any welding, unfortunately.. I'd love to learn, but that'll have to wait for now.
    Any chance someone on the forum lives in vic/nsw/sa and could whip a lower front brace together for a little extra cash their way?
    i.e. parts + labour...
    Oakleigh VIC
    I just made a batch.
    New steel, mig welded, sand blasted, powder coated and made on a jig to precisely 683mm between the bolt centres.
    There's no tolerance for out of alignment chassis with these as I designed them to retain the VW factory dimensions and there's no clearance on the bolt holes, they're 10mm holes for 10mm bolts.
    If your car is out of shape you'd need to fix the car or elongate the holes in the bar to suit.
    These clear 4speed, 020 and 02A/J boxes.
    Asking $100 a piece
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    And they make a big difference to the handling. With one of these you can turn into a tight corner and the car goes where it's pointed.
    And no, I don't get a commission from Pete, I just love getting old Golfs to handle like they should - bloody good!
    Paul
    Jun 2006
    Melbourne, Victoria
    Hi mate just sent a PM
    Oct 2014
    Asking $100 a piece
    Can I see if it fits before purchase? I imagine this wouldn't take long to install at all.. I just don't have the tools or facilities to be doing any metal fab.
    Someone else offered me an adjustable one for $120 but they haven't gotten back to me yet and I'm hoping to have something sorted by Friday (have a workshop for the day and going to be doing coilovers and other various work).
    Cheers mate!
    Oakleigh VIC
    I can modify it if it doesn't fit. Are you in in Melbourne?
    A quick check is simply to measure between the centre of the bolts with a tape measure. It should be 683mm.
    To find the centre of the bolts you can draw lines between opposite points of the bolt head. Where they intersect is the centre
    If it's only out by a couple of mm the bar will pull it back into shape.
    7? MK1 Caddy
    12 Amarok
    Oct 2014
    I'm leaving work in Mckinnon (melbourne of course) as we speak. I would love to pick it up/try it on/measure it up asap if you're free any time this afternoon or tomorrow.
    thanks mate.
