WTB- Belt set up for 1988 up Cabriolet'
I'm looking for a v belt set up for a Cabrio with the Sanden A/C Compressor.
Looking for:
A/C Compressor with (with the ends of the A/C lines (so I can braze new lines to it)
Alternator (With Plug )
Tensioner & Idler (if it has one)
Adjustor
All Bolts/ spacers and or brackets
All pulleys (Crank, Water Pump, Alternator, Idler/Tensioner (if they use one) and A/C Compressor Pulley
All belts (Just for sizing and figuring out how to install)
So basically all the stuff off the front of the engine. The A/C compressor and Alternator/belts do not have to be in working shape. Happy to pay someone to go to a junkyard and remove all this as well and markup on parts.
Thanks so much...
Contact THomas at 0406 698 723 or
ThomasFranklinFranklin@gmail.com
Text is the best way though.
Cheers!
- You may not post replies
- You may not edit your posts
Forum Rules
