Results 1 to 5 of 5
Thread: WTB: 2000 VW Passat upper oil pan
    Jun 2013
    Ballarat, Vic
    Hey Guys,
    I may be in need of an upper oil pan + oil coolant housing for a crashed 2000 VW V6.
    Basically the crash has ripped out the union tube and with it i believe the damaged the upper oil pan threads.
    Photo of a good area:
    WTB: 2000 VW Passat upper oil pan-178_7801-jpg
    And the damaged car:
    WTB: 2000 VW Passat upper oil pan-imag0323-jpg
    WTB: 2000 VW Passat upper oil pan-imag0322-jpg
    WTB: 2000 VW Passat upper oil pan-imag0324-jpg
    Should have the car tomorrow for a better look.
    Anyone have a used one in ok condition laying around?
    I am floating between Ballarat, Bendigo and Williamstown so have a fairly large range of pick up locations!
    If it has a couple of threads will glue the union in place to test the engine still turns over and if it does will replace it.
    Thanks,
    Taffy
    Jun 2013
    Ballarat, Vic
    Bump - still looking
    May 2011
    Albury, NSW
    I'm wrecking an A4 B5 V6 which are generally the same parts. Do you have the part number of the part you need and I can cross reference it off mine.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Jun 2013
    Ballarat, Vic
    Thanks for the reply, will track down a part number and get back to you.
    Yes the parts look the same from photos i can find.
    Cheers,
    Taffy
    edit: Engine has been tested by using jb glue to hold the filter on long enough to get oil through the engine but required a bucket under it as it could not be sealed. Broke off again when trying to tighten to seal.
    Jun 2013
    Ballarat, Vic
    Hey,
    Looks like they are the same part:
    https://www.hansautoparts.com/078103603AMOilPan.aspx
    078103603AM Oil Pan
    Not in a huge hurry as need to fully strip the car(limited shed space) in one go over a couple of days.
    When you get a min, let me know how much and shipped to Vic, 3356 if possible.
    Thanks,
    Taffy
