I've got some 15" steelies with tyres spare still umm pretty sure
Hi all, it won't let me post in the wanted forum so I'll try here..
I'm after some 15" rims for my mk4, happy to travel most of nsw to get them or freight.
Also after a performance 8v hydraulic cam and lifters. 260 degree preferred
Just seeing what's around. Thanks Darren.
Would be interested Dylan, where are you located?
Is to far away for me unless you would post. Thanks anyway!
Can post.
Think I only have a pair, the other pair is 14s.
Will keep a eye out for the other pair of 15s
I have a cam, with springs
Bit hotter than you are looking at though
What is the intended use?
Its going into a mk4 rally car so competing in the 1.6 class at club rallysprints ect. and in the near future prc2 in forest rallies. What do you have?
Ah yes, I know your thread
Anyway it is a CatCam
306deg
Lift: 14.50 mm
Lobe separation 106deg
It was for a 1.8 hillclimber, you will need to keep the revs up, short diff will help
Not sure if you can tune the ignition, that will make a huge difference, as would swinging the cam if you have a vernier
