bump![]()
Hi. After a towbar with removable tongue for the Golf. 75kg download is fine as i don't want anything over-engineered. OEM ADR with working wiring loom please, but on a tight budget. I'm in Brisbane. I think Mk6 should work too, but not sure on loom? Thank you
bump![]()
still searching for towbar, harness thanks.
Good morning, I'm still searching for used towbar and harness. Thanks
bump - and Happy New Year
bump - still needing a towbar assembly please
detachable tow bar and wire harness accessories please,
does anyone know if the mk6 is compatible with the mk5? I noticed different OEM VAG part numbers
do other VAG models (skoda, audi) towbars also the Mk5 TDI hatch?
need electrics too as necessary for trailer. Cheers
