bump
Hi. After a towbar with removable tongue for the Golf. 75kg download is fine as i don't want anything over-engineered. OEM ADR with working wiring loom please, but on a tight budget. I'm in Brisbane. I think Mk6 should work too, but not sure on loom? Thank you
bump
still searching for towbar, harness thanks.
Good morning, I'm still searching for used towbar and harness. Thanks
bump - and Happy New Year
bump - still needing a towbar assembly please
detachable tow bar and wire harness accessories please,
does anyone know if the mk6 is compatible with the mk5? I noticed different OEM VAG part numbers
do other VAG models (skoda, audi) towbars also the Mk5 TDI hatch?
need electrics too as necessary for trailer. Cheers
