Results 1 to 4 of 4
Thread: Mk1 disc brake conversion proportioning valves
    Mar 2010
    Hobart
    wanted to buy Mk1 disc brake conversion proportioning valves and a unicorn egg please if anyone has some
    The eggs are hard to get but not impossible, proportioning valves are a bit harder to find.
    I'm fitting rear discs to my MK1 either from my wrecked MK2 GTI or off a Seat Cupra. Whichever way I go it will leave a spare valve for sale.
    I've also got an adjustable aftermarket proportioning valve I might play with. If it works then you've got a choice of valves on offer.
    Paul
    Perth. WA
    Part you need is 533 612 151A (pressure sensitive brake pressure regulator ) VW classic parts have done a few new production runs of these however they are once again nil stock ( think each was around 125 Euro ) If you manage to find used units I would seriously consider having them rebuilt as they certainly gum and rust up if brake fluid has not been changed regularly.
    The number on the barrel will read 3 - 15 for the correct units ( 16 Valve Scirocco 2 only ) Units with 3 - 35 are for the drum brake cars only.( find them on cabriolets up to 93 )
    The Mk2 unit is completely different than what you want for a bolt in item for the Mk1 ( load sensing ) it would need the anchor plate welded to the car body as well as a lot of different piping.
    PM me if you cant find any and you seriously want rear discs... ( which btw are a heavier set up using standard VW components )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Boronia VIC
    Still available as a Lotus part too.
    Check out this old thread where we've discussed this before.
    mk1 rear disc conversion
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
