Part you need is 533 612 151A (pressure sensitive brake pressure regulator ) VW classic parts have done a few new production runs of these however they are once again nil stock ( think each was around 125 Euro ) If you manage to find used units I would seriously consider having them rebuilt as they certainly gum and rust up if brake fluid has not been changed regularly.
The number on the barrel will read 3 - 15 for the correct units ( 16 Valve Scirocco 2 only ) Units with 3 - 35 are for the drum brake cars only.( find them on cabriolets up to 93 )
The Mk2 unit is completely different than what you want for a bolt in item for the Mk1 ( load sensing ) it would need the anchor plate welded to the car body as well as a lot of different piping.
PM me if you cant find any and you seriously want rear discs... ( which btw are a heavier set up using standard VW components )
Lots of MK 1 Scirocco's...
Cheers,
Grant...
