Any Dayco timing belt kit for mk1 mk2 has manual tensioner KT70. It should fit your engine. You can also check it at the Bursons before you buy it. Easy enough when you have the sample with you. As for stud, I’m sure that can be also sourced locally, if it’s not included in the Dayco kit.
