Results 1 to 3 of 3
Thread: Kjet servo vacuum pipe
    Nov 2009
    Hi All,
    I'm after the pipe that runs from the plenum to the brake booster, it has a check valve towards the plenum end which has take offs for the distributors etc (these are sometimes block off with green caps).
    The pipe is usually a former rigid plastic so specific to the Mk1 Golf but will take the check valve on it's own too (no pipe).
    Cheers Gav
    Perth. WA
    post up the measurements Gavin, there are a few kjet versions...quite likely have what u need
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Nov 2009
    Thanks Grant, e-mail sent to hotmail address.
    Gav
