Results 11 to 20 of 28
Thread: An interesting Mk1 engine
    Jun 2011
    Quote Originally Posted by Browneye View Post
    8v head on a 1.8t turbo block gives you around 13:1 compression if you want to stay NA. All with stock internals.
    Anything other than a NA 8v doesn't look or feel right under the bonnet of a mk1. Just my 2 cents anyway
    What's involved with this?
    Machine water galleries or direct swap?
    Feb 2013
    Melbourne SE
    Easier to swap pistons into 8v block then it's a direct swap. Crank and rods are the same so are optional
    Jun 2011
    How does it end up 13:1? Quench area in head?
    Feb 2013
    Melbourne SE
    1.8t pistons have no dish/dome. If you seriously want to go this route it would be effectively unstreetable
    Jan 2011
    I'm debating putting a 4A-GZE into my MK1 for something different, might be a fair bit of fab work involved and might get shat on by people for it, but its an idea.
    '77 Golf mk1 GLS - ground up resto - Sold
    '97 Golf mk3 GL Wolfsburg Edition - JOMs, daily driver - Sold
    MY17 Golf GTI 40 Years Edition - DSG
    2010 GSX-R 750 - Daily rider
    Why all the hassle in adapting a 8v head? Just get a non turbo 1.8 20v motor, good for 125hp without any mods.
    May 2011
    Albury, NSW
    I have an AWT 1.8T that I would let for for $400 - just throwing it in there.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    May 2015
    What about the JH/ABA hybrid that I've seen around on VWVortex, thoughts on it from the more experienced folks on here?
    It seems simple enough, and I'm sort of accepting that I won't see those numbers I was initially after and I'm okay with that.
    If it comes down to it I'll just rebuild the JH, I mean, it's pretty fun to drive. I just don't get the 8.5:1 compression ratio :/
    May 2015
    But then again putting the entire 2.0 8V will give me crossflow head I was after and allow the carb/s to breath from the front of the engine bay and not soak in the heat of the headers
    Feb 2013
    Melbourne SE
    Only mk4 2.0 engines are crossflow unless you get a US ABA motor. Mk4 crossflow head on an external water pump block is doable but requires some head modifications to the oil returns.
    Mk3 2.0 with mk2 gti head is the best bang for your buck in terms of NA, but honestly the difference is barely noticeable compared to a mk2 gti complete engine. Both have been done to death and there is lots of info about.
