Results 1 to 5 of 5
Thread: Mk4 1.8T Eurodyne Maestro tuning suite
    Brisbane, Queensland
    Hi,
    Before I consider buying new, does anyone have a Mk4 1.8T Eurodyne Maestro tuning suite they would be willing to sell? Or know of a local stockist?
    Thanks
    Peter
    I'm actually running the ME7.5 on an imported AWP engine (it's a conversion into a VW T3 van), which I'm pretty sure is it's main supported ECU.
    Yeah, should be good to go. Lmk if you have no luck. I have contacts that could help you out. Just need a hex+can vcds cable or eBay special. Gavin
    OK cool will do. Further research seems to suggest that Maestro will only work with an actual cluster installed even if Immo-defeated (something to do with the licensing and the VIN), so I've reached out to Eurodyne to confirm but if it's true then for my engine/conversion which doesn't have a cluster installed it might mean Maestro isn't an option for me (unless I add a cluster in)
