Results 1 to 5 of 5
Thread: Bluetooth 9W7
    Nov 2010
    Bluetooth 9W7
    I would like to purchase a 9W7 kit including foam and cables. I already have the RCD510 unit and would like to add Bluetooth to it in my Jetta. Any ideas or links would be appreciated. I have been keeping an eye on ebay so I know what is going there. Thanks.
    Just a heads-up:
    You can't use any old 9w7 (despite it being reported as working with all cars with a white or colour MFD), as it won't respond to your steering wheel controls, therefor you can't complete the initial phone setup.
    You need a 3C8035730E. This one supports RSAP and WIFI, and while you don't need either of those features, it is compatible with our cars.
    When you install it initially and enable it in the canbus gateway, it won't work properly either, you'll get some 'no audio' issues. Just lock the car, walk away for 10 mins and come back (this allows the canbus gateway and bt unit to fully power down and reset) and then it will work properly going forward.
    When you first pair your phone, it will ask if you want to allow the BT unit to take over your SIM card identity (this is RSAP. Unless you want to use RSAP in which case you need to install the GSM antenna on your windscreen). Choose no and don't display again then it will just behave like a normal BT paired phone device.
    Jan 2015
    WTB Miltek Downpipe to suit MK4 GTI 1.8T 2001
    Sent from my SM-N910G using Tapatalk
    Nov 2010
    Thanks kamold for the heads up. This is for my 2006 Jetta so it has the half height red mfd in the dash. Don't need it to display in the dash or anything, just display on the rcd510 just like my R36 does as it is red full height mfd.
    Sorry should have read your post more carefully...
    You should be able to use the regular 9w7 kits then like 7P6035730J.
