Results 1 to 4 of 4
Thread: USBC issue...
    Dec 2023
    USBC issue...
    I need assistance with USB-C. Arteon shooting brake model 2022.
    No DVD, SD card, or USB A. The console has just two USB-C ports.
    USB C STICK 64 GB and USB C STICK128 GB were tried, but failed.
    A USB-C to USB-A cable was tried, but it didn't work.
    I tried connecting a USB-C cable to a USB-C device, but it didn't work.
    I can charge the phone, but I can't update it or use the USB to play music.
    Yes, I used FAT32, exFAT and NTFS...same issue.
    Is there anyone who can fix it?
    Dec 2007
    They appear to be sensitive to devices.
    I suceeded with these in the T-ROC https://www.amazon.com.au/dp/B09R2C9...sin_title&th=1
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Mar 2025
    Yaku
    Hi EddieP,
    Sounds really frustrating – USB-C can be a real pain sometimes! You might try checking the manual first, bacause some models have USB ports that are “charge-only” or limited to specific functions. Verify if your Arteon’s USB-C ports support full data transfer (for media updates/music playback) in addition to charging. It may be connected with the cable you are using - not all USB-C cables support data transfer. Even if you’ve tried a USB-C to USB-A cable, make sure it’s a confirmed data cable.Check if there’s a recent firmware update for your infotainment system – manufacturers sometimes release fixes for USB compatibility issues.
    For your phone, double-check that it’s set to the proper mode (like MTP or file transfer) when connected.
    If none of these solve it, it might be a quirk with the USB-C implementation in your model.
    Good luck, and hope you can get those DRM channels working again soon! )
    Dec 2023
    Quote Originally Posted by gerhard View Post
    Thanks for tip..>already tried these small Samsungs and nothing.
    Dec 2023
    Checked manual - these usb are data/charge and support full data transfer. Icon on usbc port indicate also that is data/power usb.
    I tried USB-C cables which works in another car and no problem with cables.
    Firmware update - yes, that is something need to be checked by VW tech since i book a car service for this issue. Car is still under warranty.
    I tested phone with file transfer option - still not working. Only charging.
    Most likely : USB C module gone or/and fuse for it...
    Thanks for suggestion.
    Dec 2023
    Tried same stick before...nothing.
    Dec 2023
    Tried same USB stick. No solution...
