They appear to be sensitive to devices.
I suceeded with these in the T-ROC https://www.amazon.com.au/dp/B09R2C9...sin_title&th=1
I need assistance with USB-C. Arteon shooting brake model 2022.
No DVD, SD card, or USB A. The console has just two USB-C ports.
USB C STICK 64 GB and USB C STICK128 GB were tried, but failed.
A USB-C to USB-A cable was tried, but it didn't work.
I tried connecting a USB-C cable to a USB-C device, but it didn't work.
I can charge the phone, but I can't update it or use the USB to play music.
Yes, I used FAT32, exFAT and NTFS...same issue.
Is there anyone who can fix it?
2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
2023 T-ROC R - Sunroof, Black Pack, Beats Audio
Hi EddieP,
Sounds really frustrating – USB-C can be a real pain sometimes! You might try checking the manual first, bacause some models have USB ports that are “charge-only” or limited to specific functions. Verify if your Arteon’s USB-C ports support full data transfer (for media updates/music playback) in addition to charging. It may be connected with the cable you are using - not all USB-C cables support data transfer. Even if you’ve tried a USB-C to USB-A cable, make sure it’s a confirmed data cable.Check if there’s a recent firmware update for your infotainment system – manufacturers sometimes release fixes for USB compatibility issues.
For your phone, double-check that it’s set to the proper mode (like MTP or file transfer) when connected.
If none of these solve it, it might be a quirk with the USB-C implementation in your model.
Good luck, and hope you can get those DRM channels working again soon!
