Originally Posted by
dArK5HaD0w
when i retrofitted the direct TPMS to my Superb, i did the wiring and fitting of the TPMS module first, then i had the tyre pressure sensors installed into the tyres, then i did the necessary coding to activate it all.
i followed the XaGiCO guide.
i've got a full write-up
here.
Awesome, thanks! I've added your guide to my list - this will help.
Going to hit up a family friend who is a (non-VW) mechanic, currently working part-time at a tire shop - see if he can 'help' me with it (for some extra cash of course).
BTW - the sensors and module should be genuine (both 'Huf' brand), but from separate donor cars. I assume that the sensors will still "come pre-paired to the module"? As they would if I was replacing original sensors with OEM parts.
