Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Tyre Pressure Monitoring on Arteon- where to see the tyre pressures?
    Sure you can do it in steps.
    Get the new valves installed as it won't work without them.
    Install the sensor and wiring harness, then do your coding and adaptations and Robert's your Father's brother.
    It might seem a bit overwhelming before you start but take your time and you'll realise it's not as hard as it first seems and you just need to carefully follow the coding/adaptation instructions.
    If you get stuck just come back here it's not something which will keep you off the road so you can take your time.
    Jul 2010
    when i retrofitted the direct TPMS to my Superb, i did the wiring and fitting of the TPMS module first, then i had the tyre pressure sensors installed into the tyres, then i did the necessary coding to activate it all.
    i followed the XaGiCO guide.
    i've got a full write-up here.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Feb 2014
    Quote Originally Posted by dArK5HaD0w View Post
    Awesome, thanks! I've added your guide to my list - this will help.
    Going to hit up a family friend who is a (non-VW) mechanic, currently working part-time at a tire shop - see if he can 'help' me with it (for some extra cash of course).
    BTW - the sensors and module should be genuine (both 'Huf' brand), but from separate donor cars. I assume that the sensors will still "come pre-paired to the module"? As they would if I was replacing original sensors with OEM parts.
    Jul 2010
    i got my TPMS kit (module + 4 sensors) from AliExpress.
    they work perfectly and haven't had any issues whatsoever. been 2.5 yrs now since i retrofitted this.
    the sensors were already paired with the module, and the module was already parameterised.
    hence once everything is in place, all u need to do is enable/active it by coding the various modules.
    Tyre Pressure Monitoring on Arteon- where to see the tyre pressures?-imag5360-thumb-jpg-8a0c37a6c4bbf757aea19a0e7811959f-jpg
    Tyre Pressure Monitoring on Arteon- where to see the tyre pressures?-imag5563-thumb-jpg-ec8f5f478f712ee024f26de4c03b0930-jpg
    Tyre Pressure Monitoring on Arteon- where to see the tyre pressures?-imag5562-thumb-jpg-55c0f8b41396850cac6d1e3f0ad4d2a5-jpg
    how it looks on the virtual cluster....
    Tyre Pressure Monitoring on Arteon- where to see the tyre pressures?-tpms-vc-jpg
    Aug 2023
    Bulimba, QLD
    Hey Darkshadow,
    Can you link the Aliexpress kit? Did a search and so many different models and makes?
    Would like to do it on my Alltrack Passat.
