Results 1 to 8 of 8
Thread: Sunroof Rattle
    Feb 2014
    Quote Originally Posted by MIG View Post
    You can get different grades of TPU filament that are flexible like rubber, I wonder what firmness would be needed for parts like that.
    It's quite firm/hard, so that may work.
    I applied the Kryrox and it seems very quiet so far, though I won't know until it stops raining for a bit (it's usually worst a day or so after raining).
    Feb 2014
    Applied the Krytox yesterday and so far no noises
    It's pretty magic stuff.. a few drops go a long way and I've only used a few ml to do all the sunroof and hatch rubbers. Will probably do the door rubbers too.
    Rubber went from dry and grey to smooth/soft and black - like new. I just applied a (very) sparingly-thin bead to the top of the rubbers and then smoothed it out using a q-tip.
    The 30ml bottle was only ~$50 from Germany and should last for years - also quoted ~$150 locally from VW. Highly recommended.
