Quote Originally Posted by nermal View Post
Ok, do you mostly drive on main roads/highways?
I do a lot of city driving and have auto start/stop disabled. When cruising on a main road/highway, it'll sit around 95°C, otherwise it usually settles around 98-100°C. It was ~100-105°C at stage 1 (without the oil cooler), which is similar to your stock temps.
The RacingLine tune might just run a bit hotter/leaner.. where the APR tune could be a bit richer/cooler. Though fuel economy isn't exactly "great" either =D
My Arteon also makes a little bit of belt noise, especially when cold - I thought it was normal, but perhaps that's something that needs to be looked into =/ ...
Its a mixture of highway and suburban and the occasional mountain run. My economy is slightly better than before on average so no complaints there. As you say, the Raceline tune may run a little leaner that the APR which would help explain the temp differences.
I’d be checking on that belt noise. You don’t want that to fail stuck in city traffic.
