Have you found the solution?
Hi, does anyone know of any lights that can go straight on the car? Hane not been able to find any that are suitable for the canbus setup. Thanks in advance.
Spoke to vw dealer and apparently it can't be done, having to do it with a switch.
It requires the same approach as driving lights using this or similar
CANM8 CANNECT High Beam Output Interface - Stinger Australia
I put driving lights on my car using the linked unit. Reverse lights on a manual switch are technically illegal but they work and make sure you have an internal warning light in the car to remind you to turn them off.
