Results 1 to 10 of 20
Thread: Pendulum Mount bushing - non factory
    Feb 2009
    Hi guys,
    I have a really frustrating one here , in the last 4-5 months my Arteon developed suspension noise which was really bad when going over speed hump. As i have only a month worth left of warranty i took the car to a dealer and they apparently diagnosed that the noise is coming from shock absorbers but they could not cover it because " because the software in the control unit that operates their rebound and damping parameters has been modified to allow them to operate outside what the manufacturer had them set to." I said to them what and they repeated it and i got that in an email.
    My car does have APR stage 1 but that has nothing with suspension so i complained to the management and they took the car back . I got a call today from them today and they said that they identified where the noise is coming from but "as its aftermarket part they cannot cover it under warranty " they said it was a Pendulum Mount bushing that is an aftermarket part fitted on my car is rubbing and making noise , i was even more surprised to hear this and i asked why would someone even replace that part and they said because of a car being involved in an accident and that's where i completely lost any faith in this dealership as my car was never involved in an accident , the only time my car spent more than one day was at their dealership.
    As originally they thought that it was a shock absorber they replaced one of them and they said they were going to leave it on a car , last time i checked these are replaced in pairs and it a very unsafe thing to replace just one.
    They have attached the photos of what they said is an aftermarket bush and its purple in color , would anyone one spare some time and try to check on their car if it is black or purple Pendulum Mount bushing - non factory-arteon-bush-jpgPendulum Mount bushing - non factory-arteon-bush-image-2-jpg
    I think that this dealership is trying to hide something as nothing they report back makes sense unless the car was damaged before the sale and that during a repair they fitted this after market part . I bought a car in October 2018 as a new car
    Arteon 2018 ,white , Sound and Style Package , Sunroof, APR Stage 1,Turbo Inlet ,K&N
    Feb 2014
    That's very interesting... I think poweflex do purple pendulum (dogbone) mount bushings. Supaloy and Superpro also have purple bushings with some of their products.
    I'd be asking the shop that did your APR tune.. may have been part of a package or something.
    I have the RacingLine dogbone mount insert that fills in the gaps and makes a big difference to the cabin NVH (marketed as a "growl"). Though does improve the power delivery - more direct and less elastic-y..
    Pendulum Mount bushing - non factory-20230616_124957-jpg
    Feb 2009
    Thanks Nermal, so from your experience this color is after market part?
    Feb 2014
    I have a MY18... but it doesn't look right to me. It should be a 2-piece "puck" with whitish plastic outer and black rubber inner that has gaps.
    Unless the newer Arteon's came with a different setup. Hopefully others can weigh in
    I'm also not sure about that purple bushing extruding out the top and sitting under the ?sway bar? in your photo - though I haven't seen above the dogbone mount before, so it could be normal..
    FWIW - anything messing with your sway bar is likely to produce suspension noises over bumps.. (ie. if there's any way that it could be contacting with that purple bushing?)
    Feb 2014
    Actually, it looks like genuine ones do come in purple - VAG parts sell them: 5Q0198037F - (MQB) Dogbone Subframe Mount Kit (PUCKS) - Volkswagen Gol– VAGPARTS Australia
    The top still doesn't look right.. perhaps the top part of the 2-piece "puck" is petruding up against your sway bar. They need to be pressed into the subframe like other bushes.
    You haven't happen to have been running a single (upper or lower) dogbone mount insert have you? This can lead to a failure of the mount due to uneven force/motion. That's why RacingLine etc produce them in pairs (upper and lower)
    Can you get a better pic of the puck?
    It will have a part number and other identifiers on there.
    From way back here it looks like there might be 'VW AG' on the black part. Given you can't seperate that from the purple as they are bonded that would make it OEM.
    But again can't really make out from the pic.
    Feb 2014
    The more I look at it, the more I think that the purple disc (puck) protruding out the top is the source of your suspension noise (assuming it's contacting that sway bar)..
    Either way you probably need it replaced and/or re-pressed into the subframe.
    034 do uprated (solid) replacements that should compliment your APR tune with more direct power delivery. Though it will add some extra NVH to the cabin.
    Feb 2009
    Thanks guys, spent some time under the car today to try to get a better picture buts just too hard as there is not enough room, i will attach the best ones . And yes , that top part is definitely the noise source the dealer diagnosed it and this morning i sprayed a bit of silicone spray and went for a drive and the noise was gone .
    As far as i know , no work ever was done on that part and i'm the first owner so what ever was installed in a factory it should be there.
    This is what the dealership said:
    We have replaced the N/S/F strut as per previous communication. This did not resolve the rubbing noise evident over bumps.
    Now after investing 7 hours of senior diagnostic technician time we have identified that the Pendulum Mount bushing is non factory and is moved up in the subframe and rubbing on the sway bar. As the sway bar moves with suspension in the images attached you can clearly see where it is rubbing.
    As this time is not claimable under warranty the costs should be passed onto the vehicle owner however you have made it very clear that you do not know what has happened and therefore are not willing to contribute.
    The Pendulum mount would require removal and replacement to resolve it rubbing on the sway bar.
    Mornington Peninsula, VIC
    That part is marked with VW AG and has a moulding date of 2018; it seems to line up with that being original?
    Can you take a better pic from the top at all? see if there is some type of insert been installed?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Feb 2009
    Hi MIG , there is no way of accessing the top , there is no space at all .
    So, purple , black and that metal piece are all molded together ? If that's the case then this is very worrying , people that are servicing and doing warranty work on our cars have no clue about it.
