Just had the 30,000km service and they inspected the cooling system and everything went ok with the pressure test.
No specific reason and no codes given as to why there was a spike in coolant and engine oil consumption recently. Told to keep an eye on it and bring it in should it occur before the next service.
The sunroof mechanism was cleaned and lubed, so hopefully the rattles will be gone or at least subdued for a while
The Discover Pro head unit got a firmware update, so it might finally work properly with the iPhone 11 Pro via Bluetooth.
Front brake pads are currently at 4.9mm & rear brake pads are at 7mm, so it's highly likely front pads will need replacing before the next major service. I'm told front pads will cost over $900 to replace .... ouch!!
