Fuel additives
Does anyone use fuel additives (eg. octane booster). Are these good or bad for your engine? which brand(s) do you use or recommend?
VW will sometimes provide fuel additives (valve lubricant IIRC) when you pick your car up from a service.
- thinking there should be some general EA888 place for this kind of question
