Results 1 to 7 of 7
Thread: Dynamic Road Sign Display - VCDS/ODB11
    Apr 2018
    I've confirmed this tweak is working
    stolen from A guide to enable EU specific features for AU Spec Tiguans
    1. Module 5F
    Adaptations
    Car_Function_List_BAP_Gen2 traffic_sign_recognition_0x21
    Set to Active
    Car_Function_Adaptations_Gen2-menu menu_display_road_sign_identification
    Set to Enabled
    Then go to Coding
    Long Coding
    Byte 24, activate Bit 6
    2. Module A5
    Then go to Coding
    Long Coding
    Byte 16, activate Bit 4
    3. Module 17
    Then go to Coding
    Long Coding
    Byte 5, activate Bit 2
    Then you need to disable Road Sign Fusion.
    4. Module A5
    Adaptation
    Road sign detection fusion mode
    Change from Road sign fusion to Road sign detection
    If you have HUD in your Tiguan, the following coding will enable speed signs to be shown on it (For NZ and other countries)
    Module 82
    Coding
    Long Coding
    Byte 0, Activate Bit 0.
    Reboot the infotainment system.
    Arteon & T-Roc
    May 2018
    Does this tweak result in any error codes or warnings? I seem to recall reading somewhere that it creates a message appearing very time nav starts or similar or am I barking up the wrong tree?
    Apr 2018
    Yes, once you drive up the road it will display a warning on the AID for a few seconds. The warning goes away on its own and is not intrusive.
    The warning will show even if it picks up a sign and is showing it.
    It works well regardless.
    Arteon & T-Roc
    May 2018
    Thanks, will give it a go!
    Dec 2010
    What's the warning message it gives?
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
    Apr 2018
    Dynamic Road Sign Display - VCDS/ODB11-img_20180618_081810-jpg
    Top is the message that shows for a few seconds.
    Buttom is what shows in the car status view.
    Arteon & T-Roc
    Apr 2023
    Gold coast Australia
    New to this can you explain to me how I do the long coding once I'm in there. There is a large number on top line with a series of smaller numbers beside it, under that is a line on left it says exmple byte 00 and right hex 2. Then a list of bit numbers what do you change to get the settings you are saying please.
