Results 1 to 9 of 9
Thread: Things to look out for 2018 Arteon
    May 2011
    Braybrook
    Hi all,
    Been a while since i got back into a VW. Looking to purchase a 2018 Arteon with 110,000km. Are there anything of concern that I need to be aware of? Thank you heaps in advance for the advice.
    Aug 2021
    My quick snapshot of things to check:
    Service history re: (oil changes, DSG and Halex fluid changes and all standard service items)
    Water pump - the Achilles Heel of the EA888 - will require replacing as some stage
    Suspension - take the car for a good test drive over uneven ground, speed humps, car park entries/driveways etc and listen for clunks, squeaks, rattles and groans. Strut mount bearings can become noisy, and the front lower control arm bushes are a known issue.
    May 2011
    Braybrook
    thank you heaps.
    Quote Originally Posted by petemac110 View Post
    Thank you heaps for that.
    Mar 2024
    If it's got a sunroof, check the exterior trim around the sunroof for cracks.
    Pacific Paradise QLD
    Quote Originally Posted by Darty View Post
    And drains for blockages and spider traps
    Aug 2021
    AMEN TO THAT!
    I've been on the receiving end of flooded sunroof drains, wet BCM and electronics, and a dead car for a few days. Not fun at all
    Aug 2018
    Check for cooling leaks. VW in general is notorious for leaking water pump/thermostat housings. Had mine replaced at 90k.
    May 2011
    Braybrook
    Cheers to all, thanks heaps for that.
    Jan 2020
    Western Sydney
    2018 with that klms i'd pas on straight away mate.
