Originally Posted by
Hillbilly
Try this go to 17 dashboard/Adaptation/ display depiction and it gives you 4 options Mine is on the same as candyflos's reply 161 top one with dots and no 30.50.70 etc. is no 3 according to my history.
Is in a Tig but will be similar and you dont need credits to change it with a PRO
That was it, thanks!
It was on "Version 4". Setting it to "Version 3" gave the default GTI theme and "Version 2" was the correct setting - R theme without the half steps.
