I easily used my OBDEleven to change the wattage amount and the start/stop has been successfully disabled since this so no more manual press of the button required.
I can find what I changed if needed, it's been a couple of years since I did this.
I believe I've disabled the nag screen on start up
Go into Control Units -> Multimedia (5F) -> Long Coding -> byte_23_Initial_Disclaimer: off
What you are looking for isn't another view you'll need to add through an OBD11 app or with long coding, it's from playing with the view options for the digital cockpit / instrument cluster within the settings of the car. You are currently on 'Consumption & Range', whereas I think you need to be on 'Speed & Gear'. Access via the view button (the overlapping rectangles!) on the right of the steering wheel.
Cheers,
Matt.
Matt, I'm pretty sure that you can't remove the "half-steps" from the speedo (i.e. the 10, 30, 50, 70km numbers) via your proposed method - it needs to be done via coding (whether via a one-touch coding arrangement in OBDeleven or Carista) or separate coding.
Nermal's picture shows the "half-steps" and the picture I posted does not.
