That's made a big difference, well done, looks great!
I enabled the Throttle Pedal Response app in OBDEleven (under: Car -> Apps).
There seems to be a decent reduction in accelerator pedal lag/sogginess. I think it may have firmed up the pedal a little too.
Not sure what coding changes it makes - should probably do another full backup and then I can diff the files.
Here's what the app looks like in OBDEleven, with Responsive setting selected:
Enabled "Lighting of Area View" app, which works in reverse when dark (side mirror lights come on to illuminate the area view).
Also changed the Soundaktor volume to 50% - used the app because laziness. I'll probably disable it altogether after getting the stage 1 tune.. seems a bit lame to have a fake engine sound speaker.
So far, I think the throttle pedal response change is my favorite - makes a difference to drivability. Also like the Audi mod and 30 interior light colors (using blue atm).
I did a another full backup before the latest 2 mods and did a diff against my "stock" backup.. some interesting changes - may try to fix the b0rk3d "Folding Mirrors with IGN" mod when I have the time (can see the settings it changed)
