Hey guys, do the your Arteons have the dynamic sweeping rear turn indicators?
I saw the reviews on YouTube, I think Canada is the same way. Anyway I have a set of the Euro Tails with the amber indicators and I need the adaptations to get the signals to be dynamic. Right now they just flash like normal with no fanciness.
This is how they work at the moment.
Ahh I see. Yeah ours do that cascading thing. Let me check my coding and see what I can dig up.
My car: MY18 Arteon
My car #2: MY22 Volvo XC40 Pure Electric
Her car: MY22 Skoda Octavia Limited Edition Wagon
Maybe the "Pacecar" setting you can do with an OBDELEVEN is what you want. That flashes half of each one alternately when its turrned on and works on highline Golfs as they have two piece turn indicators. Doesnt work on TIgs ans they only have single indicators
Look in the Golf Mk7 on Autoinstructs site
Volkswagen MK7 Golf OBDeleven / VCDS Tweaks List – AutoInstruct
So...I don't know where this is in OBDII, but in VCDS - I think this is what you might want. It's on 09-Cent. Elect.
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken not active
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger separte
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing not active
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken active
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung active
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10 active
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay 50 ms
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken not active
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen Warnblinke_zulaessig
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen 3
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken not active
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 not active
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing active
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS PreCrash_aktiv
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links active
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts active
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken active
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing active
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken active
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken active
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz not active
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS active
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN active
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf active
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu active
My car: MY18 Arteon
OBDELEVEN for GOlf 7.5
Alternating Indicator Lights (Pace Car Lights)
For vehicles with LED tail lights, the inner an outer rear indicators will alternate when indicating, or with hazard lights.
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(16)-Leuchte2SL VLB10-Lichtfunktion G 2
Select: Blinken Links Dunkelphase
(1-Leuchte2SL VLB10-Dimmwert GH 2
Select: yeni değer 0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2
Select: yeni değer minimize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3
(1-Leuchte3SL VRB21-Dimmwert GH 3
(19)-Leuchte3SL VRB21-Dimming Direction GH 3
Sorry dont know how the smilies got there but they should be 8's
These were set to what you have here. I'm thinking its part of the individual tail light lamps.
OUTER TAIL LAMPS (EU) (4 PINS PER UNIT)
MX3 Left Tail Lamp
M4 Left Tail Lamp Bulb (Pin 2)
M6 Left Rear Turn Signal Bulb (Pin
M9 Left Brake Lamp Bulb (Pin 5)
Ground (Pin 3)
MX4 Right Tail Lamp
M2 Right Tail Lamp Bulb (Pin 4)
M8 Right Rear Turn Signal Bulb (Pin
M10 Right Brake Lamp Bulb (Pin 5)
Ground (Pin 3)
INNER TAIL LAMPS (EU) (5 PINS PER UNIT)
MX5 Left Tail Lamp
M16 Left Back-Up Lamp Bulb (Pin 7)
M49 Left Tail Lamp Bulb (Pin 4)
M80 Left Rear Turn Signal Bulb (Pin
L46 Left Rear Fog Lamp Bulb (Pin 6)
Ground (Pin 3)
MX6 Right Tail Lamp
M17 Right Back-Up Lamp Bulb (Pin![]()
M50 Right Tail Lamp Bulb 2 (Pin 6)
M81 Right Rear Turn Signal Bulb 2 (Pin
L47 Right Rear Fog Lamp Bulb (Pin 7)
Ground (Pin 3)
OUTER TAIL LAMPS (NA) (4 PINS PER UNIT)
MX3 Left Tail Lamp
M6 Left Rear Turn Signal Bulb (Pin(Adaptation 28BR 32)
M9 Left Break Lamp Bulb (Pin 5) (Adaptation 20BR 35)
M21 Left Brake/Tail Lamp Bulb (Pin 4) (Adaptation 28BR 32)
Ground (Pin 3)
MX4 Right Tail Lamp
M8 Right Rear Turn Signal Bulb (Pin(Adaptation 27NSL 32)
M10 Right Break Lamp Bulb (Pin 5) (Adaptation 21BR 35)
M22 Right Brake/Tail Lamp Bulb 9 (Pin 4) (Adaptation 27NSL 32)
Ground (Pin 3)
INNER TAIL LAMPS (NA) (3 PINS PER UNIT)
MX5 Left Tail Lamp
M16 Left Back-Up Lamp Bulb (Pin 7) (Adaptation# 29RFL 32)
M4 Left Tail Lamp Bulb (Pin 4) (Adaptation# 16BLK 37)
Ground (Pin 3)
MX6 Right Tail Lamp
M17 Right Back-Up Lamp Bulb (Pin 7) (Adaptation# 29RFL 32)
M2 Right Tail Lamp Bulb 2 (Pin 6) (Adaptation# 17BLK 37)
Ground (Pin 3)
Howdy gents. Another yankee Arteon owner here. Hope you're all doing well in regards to the fires. Truly sad what's happening and wishing you guys the best!
Quick question for you. Do your cars come equipped with DLA from the factory is it something you need to enable? I ask, because here in the states, the Arteon only comes with High Beam Assist. We've tinkered around with VCDS settings we've found mostly on here in the Passat forum, and have a half-assed form of DLA enabled.
I believe that, in order to get a fully working DLA requite a flash to the 4B module with VCP, but, not 100% sure on that. I'd be curious if you do have DLA, what settings you guys have in the following modules: A5 and 4B, and some of your adaptations in 09. We're going buy this post here, in the MQB Tiguan forum. It enables DLA for sure, however, it's not a proper setup as there seems to be some other parameters that are need via the flash. Here's the post I'm referencing:
my journey to activating DLA on a MY17 Tiguan
If you guys could shed any light on this, would be a great help! Thanks again for any help!
This is a great video specific to the Arteon.
YouTube
I don't think there is an option for always on and you have to flick the left stalk forward.
Arteon & T-Roc
