Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 186
Thread: Arteon VCDS / OBDEleven Tweaks - Confirmed working
  1. #61
    Jun 2018
    Gibraltar
    Quote Originally Posted by DreamensioN View Post
    LOL! Even with 10 colours, I only really use about 5.
    How do I get 20? LOL
    even at 10, it does not show all the colours properly anyway so i cant imagine that much of an improvement with 20
  2. #62
    May 2018
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe = 64
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe = 255
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe = 175
    Ignore the exact ENG codes - just put the numbers in the slot you want the factory white to be in.
    Thanks for this DreamensioN- got white back on the board!
  3. #63
    Sep 2018
    United Kingdom
    Hey guys....OBD came today and picked up my Arteon Monday....I can’t get the app to connect to the device. I have pushed it as hard as I can into the slot as someone earlier advised but still no joy.....am I missing something / I got a faulty OBDEleven?
  4. #64
    Jun 2018
    Gibraltar
    Do you see a red light on the device when you plug it in? As soon as you do, you should see a blinking red light. If you dont thwn its either faulty or not plugged in properly. I dont have to force it at all so dont do it too hard or you might damage the pins.
  5. #65
    Sep 2018
    United Kingdom
    Na no red lights when I plug it in....tried switching ignition on and having the car started ��
  6. #66
    Jun 2018
    Gibraltar
    Sounds like its faulty then (assuming its correctly plugged in.. i hear some people here say they needed some sort of an extension to plug it in, i didnt need it though).
  7. #67
    Apr 2018
    Arteon & T-Roc
  8. #68
    Mar 2017
    Tasmania
    I know that passats require the extension. And arteon dash is a straight lift from Passat, so...
    Sep 2018
    United Kingdom
    Cheers guys......tried it in a friends golf and lit up like a Christmas tree.....extender it is....just ordere this from amazon. Only because it’s in the uk and will be here tomorrow [1.5m] Eximtrade OBD2 OBDII Extra Long Extension Diagnostic Cable 16-Pin Male to Female: Amazon.co.uk: Car & Motorbike
    Thanks for the support....
    aside from the the ambient lights colour change, digital display dots (that’s what someone called it) and video in motion anything you would recommend to do?
  10. #70
    Apr 2018
    These are the items I've done:
    Speed sign detection and display on HUD
    Dynamic Road Sign Display - VCDS/ODB11
    Refuel amount in cluster
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Oil temp in cluster - This is my favourite of all the changes
    Volkswagen MK7 Golf OBDeleven / VCDS Tweaks List – AutoInstruct
    Fan speed on auto
    TMC
    A guide to enable EU specific features for AU Spec Tiguans
    Needle sweep
    Bouncy dots
    Mk2 Tiguan VCDS Tweaks
    R style dash
    This is on my list to do:
    Increase number of blinks on quick signal
    DRL control from infotainment
    Disable nags
    Fold only on ignition (not on doors)
    Dash colours
    Beep on lock
    Rear DRL
    Auto windows close in rain
    Arteon & T-Roc
