Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 186
Thread: Arteon VCDS / OBDEleven Tweaks - Confirmed working
  1. #151
    Sep 2019
    I easily used my OBDEleven to change the wattage amount and the start/stop has been successfully disabled since this so no more manual press of the button required.
    I can find what I changed if needed, it's been a couple of years since I did this.
  2. #152
    Pacific Paradise QLD
    Quote Originally Posted by SHANEO79 View Post
    Hmmm Strange Everyone else changed the VOLTAGE. Since 2020 VW has disabled our ability to disable this function
  3. #153
    Feb 2014
    I believe I've disabled the nag screen on start up
    Go into Control Units -> Multimedia (5F) -> Long Coding -> byte_23_Initial_Disclaimer: off
  4. #154
    Feb 2014
    Also used Apps to change the "Virtual Cockpit Theme" from GTI (default) to R and the "Virtual Cockpit Style" from Standard (default) to Dotted.
    Arteon VCDS / OBDEleven Tweaks - Confirmed working-screenshot_20220813-150909_obdeleven-jpg
    Here's what it looks like:
    Arteon VCDS / OBDEleven Tweaks - Confirmed working-20220813_151344-jpg
    Does anyone know if there's a way to remove the half steps in the speedo? Seems a bit crowded with all the odd smaller numbers..
  5. #155
    Aug 2021
    Quote Originally Posted by nermal View Post
    It’s definitely doable, but I used Carista to change mine so I’m not sure which theme that equates to on OBDeleven:
  6. #156
    Feb 2014
    Quote Originally Posted by petemac110 View Post
    Do you have the "Dotted" style enabled? I think that may have been when it changed...
    Maybe I can take a backup and look at the diff 🤔
  7. #157
    Aug 2021
    Maybe I can take a backup and look at the diff 樂
    Carista doesn’t appear to have the ‘dotted’ style as an option, but it has eight different themes which include the above layout with and without the half-steps.
  8. #158
    Feb 2014
    Thanks, I'll do some searching around half-steps. Probably in the long coding somewhere that I can flip a bit on.
  9. #159
    Jul 2012
    What you are looking for isn't another view you'll need to add through an OBD11 app or with long coding, it's from playing with the view options for the digital cockpit / instrument cluster within the settings of the car. You are currently on 'Consumption & Range', whereas I think you need to be on 'Speed & Gear'. Access via the view button (the overlapping rectangles!) on the right of the steering wheel.
    Cheers,
    Matt.
  10. #160
    Aug 2021
    Quote Originally Posted by dairyfloss View Post
    Cheers,
    Matt.
    Matt, I'm pretty sure that you can't remove the "half-steps" from the speedo (i.e. the 10, 30, 50, 70km numbers) via your proposed method - it needs to be done via coding (whether via a one-touch coding arrangement in OBDeleven or Carista) or separate coding.
    Nermal's picture shows the "half-steps" and the picture I posted does not.
