Results 1 to 6 of 6
Thread: Arteon towing
    Feb 2009
    Arteon towing
    Hi all and happy New Year
    I'm exploring an option of towing a camper trailer/ caravan with Arteon and looking at the towbars available they are all rated around 100 kg towball weight and most caravans that I saw are anywhere between 110 and 130 kg ball weight , then there is Wesfalia towbar that is rated at 210 kg but from what I understand max towball weight for Arteon is 90kg.
    I do not know much about towing capacities so any recommendation is greatly appreciated as I really don't want to get another towing vehicle and I know in Europe they are towing caravans with much smaller vehicles so Arteon should be capable of doing the same.I'm based in Sydney so if anyone can recommend a place that would be great..
    Arteon 2018 ,white , Sound and Style Package , Sunroof, APR Stage 1,Turbo Inlet ,K&N
    Pacific Paradise QLD
    The towball weight is set by the manufacturer and should NOT be exceeded.
    Even if you put a towbar with a 300lb towball capacity the limit remains at 90lb as set by VW.
    Euro vans are constructed differently to Aussie ones which are built much heavier and so Euros have lighter ball weight.
    Whatever you do do NOT load it rear heavy to lighten ball weight or you could visit the nearest guard rail after leaving home.
    Been there tried things Hauled a 3000kg van right around AUS.
    I suggest for a Van you look at a Euro van Like Bailey, Adria, York, Jurgens or similar. NOT this one LOL
    Log in to Facebook
    Feb 2009
    Thanks for the info, i decided that i will not do any towing with Arty, we'll look into replacing our Camry Hybrid with a Pajero and go from there
    Quote Originally Posted by dubrav View Post
    Older Pajeros are limited to 3000kg and Im not sure about the ball weight. I would look for a not too high K.s Landcruiser 100 TD or even a 200ser TD which have a 3500kg tow capacity and a 350kg ball limit. 250,000km on either of them is nothing really
    Feb 2024
    Los Angeles
    Earlier models of the Pajero have a towing limit of 3000kg, and the ball weight is uncertain. I'd suggest seeking out a Landcruiser 100 Turbo Diesel with moderate kilometers or possibly a 200 series Turbo Diesel, both of which can weed seeds amazon discounts tow up to 3500kg and have a ball weight capacity of 350kg. For these vehicles, having 250,000km on the clock isn't particularly significant.
    Quote Originally Posted by Theresia62 View Post
    Earlier models of the Pajero have a towing limit of 3000kg, and the ball weight is uncertain. I'd suggest seeking out a Landcruiser 100 Turbo Diesel with moderate kilometers or possibly a 200 series Turbo Diesel, both of which can tow up to 3500kg and have a ball weight capacity of 350kg. For these vehicles, having 250,000km on the clock isn't particularly significant.
    Did I read that right A Landrover You have to be joking Try getting any parts for that in mid Australia.
    Whereas Toyotas are everywhere because the Mines use them and parts are available in fairly remote places because of this. If a 200 ser make sure is later than 2009 as the early V8s were problematic. A diesel is the way to go. We had a 300kg van and towed with a 2005 Landcruiser TD got about 15l per 100km.
