Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Arteon sound system issue
    Pacific Paradise QLD
    Using the setup on the Dynadio you can alter where the most of the sound comes from to the extent you can have it pointed right at your head and therefore different volume levels will be set for each speaker. Should be able to fade it back and forward in the cabin as well so make sure it isnt rear oriented too much
    Using the setup on the Dynadio you can alter where the most of the sound comes from to the extent you can have it all concentrated right at your head and therefore different volume levels will be set for each speaker. Should be able to fade it back and forward in the cabin as well so make sure it isnt rear oriented too much
    Jun 2020
    Tarneit VIC
    Quote Originally Posted by DreamensioN View Post
    But they're replacing it under warranty?
    And yep - I'm pretty sure it is normal for front & rear speakers to be different wattages. It all depends how the sound system has been setup. I've had cars where the larger speakers were in the back, and vice versa.
    Yes they are fixing it under the warranty.
    Jun 2020
    Tarneit VIC
    That’s what I thought. However when I focused the sound to rear, the output is significantly lower than the front. There’s almost no bass either.
    Also, I don’t get the how the subwoofer works. What’s the best way to check the sub?
