Originally Posted by
BO11OS
Adv to go with a EQT Vortex XL Turbo, I am told with the Galano Pro ECU/TCU tune it will be very responsive down low still & pull hard up top also going with the pro fuel flex setup so I can run 98 & or E85,you can mix them in the tank & the sensor adj the tune to the ethanol in the fuel
Sounds very interesting. I'm going to start with an ECU/DSG tune, probably with intakes/piping. will then see where that leads...
From what I can see, that turbo is a couple of grand for the part? What kind of budget would you suggest for something like that - does it require other upgrades too (sorry I'm a turbo n00b)?
My biggest issue with the Arteon's performance (vs my R36) is low end responsiveness, so looking at ways to improve that.
