Originally Posted by
ANDREWF
I just went through this process again, failed to locate the update on my Samsung 64gig sdcard in exfat, and also failed on a Verbatim 32gig.
I tried a USB stick with no luck. Had to buy another Sandisk 32gig sdcard & that worked again first time.
What did you format the Verbatim 32gb one as and how big was the Stick
Also note that you can only load 1000 tracks straight onto the internal SSD jukebox
I thought I had 2000 and then noticed half hadnt loaded
However if you put them on in 1000 amounts it will add to previous ones up to about 3000 max
