Results 1 to 10 of 62
Thread: Arteon Brake upgrade
    Jan 2020
    Western Sydney
    Vedi, Still looking at this stage as no one has anything in stock, for the money they want I don't see a 6k benefit but if we get around 370 to 380 kws at the wheels i'll prob need something better to slow th is bad boy down.
    Dairyfloss, I have seen on some Gold R's they have an R calliper not sure if it is 4 or 6 pot though & I think maybe only in America not sure.
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by BO11OS View Post
    just my personal opinion, golf R oem calipers are underrated they just come with average pads and discs from oem.. but still do a decent job for a certain time then start to fail quickly.
    consider getting dba 4000 rotors (350 - 450) and dba xtreme xp orange / XP650red pads(think they are the same from my research... same product codes.. same heat threshold specs.. )... going to get a much better result over oem and might be all you need really for 500 - 600 instead of 6k
    Feb 2014
    Quote Originally Posted by amunra View Post
    Thanks, the DBA pads/rotors are an interesting option and may be a good temporary plan B if the stage 3 brakes don't fit, though fitment is looking good so far =)
    I was also looking at ordering some Brembo 345mm (4Pot) Porsche Macan or Audi RS options online, but my long-term plan was to go 380mm Stage 3 eventually anyway. The Golf R (2 pot) calipers were also a consideration, but there wasn't too much of a price difference for the 4pot options - especially given the addition €430 in shipping. Here's the site I was looking at: Vw Arteon Big Brake Kits
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by nermal View Post
    dont u guys have golf r brakes as standard?
    Feb 2014
    I think the rotors are the same, but the Arteon calipers are single piston, where the (new) Golf ones are 2pot - tho I could be wrong
    Arteon Brake upgrade-arteon-png
    Feb 2015
    Sydney, Australia.
    interesting. thought it was the same gear as the golf r... thats a shame for arteon drivers if VW are cheaping out a bit.
    audi TTS brakes are like golf r brakes but lighter...... if u can find them..
    otherwise i think 2nd hand 4pots (porsche audi) off a wreck are probably the best buy if ur gonna replace the calipers... otherwise just replace the disc and pads like (dba4000 and dba xp) even on a single pot should be good with stage 1 - 3 (depending on what ur doing regularly).
    why ur considering stage 3 brake kit on a stage 1 car..... only if ur going to do laps and laps at a circuit and regularly... u might regret ur purchase very quickly.
    P.S after doing some reading online they are the same brake calipers as golf r.. open to being corrected if someone can prove that.
    May 2007
    @amunra - it appears you have corrected yourself and yes, to confirm the Golf R / Superb 206TSI 4x4 / Passat 206TSI R-Line / AUDI S3 / Tiguan 162TSI all run identical (Front) 340x30mm vented rotors with the same sized single piston calipers, however the Golf R / AUDI S3 have a cover plate on the caliper, purely a decorative plate.
    And no, the AUDI TTRS front calipers are NOT like Golf R Calipers, they are a 4 piston caliper.
    The new MK8 Golf R has 357x34mm rotors with newly designed 2 piston calipers.
    I personally run the following on my ŠKODA Superb 206TSI 4x4:
    - Clubsport S (semi 2 piece drilled) front rotors - Part No. 5Q061301C
    - Clubsport S front pads - Part No. 5Q0698151L
    This combination is excellent, a vast improvement over standard.
    Arteon Brake upgrade-164658658_459167681967278_2089604554991263660_n-jpg
