I recently had ATE ceramic brake pads fitted to the front and rear, and as the front discs were also found to be wearing down, I decided to replace the stock rotors with Brembo drilled rotors at the same time. The ATE pads were a bit over $420 + labor, and the Brembo front discs were $630 + labor.
Very happy with the combination, after about 3-4 months of driving now; and loving that there is next to no dust on the Rosarios, using the ceramic pads!
Cheers,
Matt.
- You may not post replies
- You may not edit your posts
Forum Rules
