Hello, I’ve got a mk7 64 plate high-line with Aid and Mib2 retrofitted. By reading in this thread I figured out to get the slider for adjusting the light brightness ( footwell-door cards) but I can’t adjust separate like used to be on mib, just to adjust footwell and door cards together . What I really want is to match the Aid colour with my mib2 but can’t find farbliste_hmi option in Vcds.
ATM i can only adjust the brightness on footwell and door cards together. Sorry for my English. Thanks a lot. I can’t see an option to upload a photo.
Based on what I have read so far, if i have the lowest ambient package (only white-coloured door strip) on my Passat MY2016, this means that my led is 1-colour and it cannot be changed via obd11?
Is my understanding correct?
i have 2018 tiguan and i would like to change it back to original colour (blue). do you have any idea how i can do this? i used obdeleven app to change it back to original (did not use the coding) but its red as you can see and i have no idea how i can change back to original colour blue. help will be great thanks.
We are in same boat. I already checked required parts for this job (installing ambient light inside passat). Apparently, we have only white, so all door trim and trim above infotainment centre required replacement + wiring box + labour = 5K.
So, I just give up on that and make new goal: my next car will be Arteon
Sent from my SM-G986B using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
