Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 66
Thread: Arteon Ambient light & LED Colour change
    Aug 2017
    Uk
    Int. light, 2nd generation: weicher Farbwechsel: active
    soft colour change-not needed
    Int. light, 2nd generation: Instrumententafelbeleuchtung mehrfarbig: active
    AID colour- needed
    Int. light, 2nd generation: Mittelkonsolenbeleuchtung mehrfarbig: active
    center console colour-not needed
    Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed
    needed
    Interior light, light configuration: Mittelkonsolenbeleuchtung: installed
    again Center console- not needed
    Interior light, light configuration: LIN-Dachkonsole lokal aktivierbar: active
    roof consol- not needed
    Interior light, light configuration: Ambientemenue mit globalem aus: active
    gives you a off button in background lighting to switch off door and footwell lighting
    Interior light, light configuration: Ambientemenue mit alle Zonen: active
    Adds the “background lighting” buttons in settings- needed
    Interior light, light configuration: Ambient_Farbliste_HMI: active
    gives you the colour slider at bottom of background lighting screen- needed
    Interior light, light configuration: Frei_Farbwahl_ueber_HMI: active
    Turns off the brightness slider in the background settings screen, so not active if you wanna dim the footwell door lights
    Aug 2017
    Uk
    If that headlight warning thing annoys you, that can be turned off to
    Dec 2017
    QLD Australia
    Now all i need is to get them all to flash and cycle thur the colour spectrums and i could turn my car into a disco LOL.... thanks guys.
    Sent from my SM-G935F using Tapatalk
    Dec 2017
    QLD Australia
    Quote Originally Posted by Jap View Post
    Display depiction gives you the bouncing dots in between the dials
    tube version gives you the dials (but you need the newest version of VCDS)
    Hi Jap can you elaborate on the bouncing aspect got the dots dials but no bounce ? Using obd2 tube ta
    Aug 2017
    Uk
    When you switch views the balls bounce
    Oct 2017
    Copenhagen, Denmark
    Quote Originally Posted by DR074 View Post
    Tweak: Colour Change in AID
    Vehicle: Passat B8 206TSI R-Line MY17 (AUS)
    Tweak completed with OBDEleven, should work with VCDS, but may be slightly different on newer cars (My18s)
    Not sure if all the below needs to be done, but these are the settings on my car and it works.
    Control unit: 5F Information Control Unit
    Adaptations:
    Car_Function_Adaptations_Gen2: menu_display_ambient_illumination: activated
    Car_Function_Adaptations_Gen2: menu_display_ambient_illumination_over_threshold_h igh: activated
    To get the cool dials in the AID
    Control unit: 17 Dash Board
    Adaptations:
    Display depiction: Version 3
    Tube_version: variant_4
    Control unit: 09 Central Electrics
    Adaptations:
    Ambientelicht Farbliste: Rotwert Farbe 1: 144
    Ambientelicht Farbliste: Gruenwert Farbe 1: 24
    Ambientelicht Farbliste: Blauwert Farbe 1: 28
    Change all colours up to 10, none can be R: 0, G: 0, B: 0 as none will work
    I got the numbers for RGB from MS Excel (format cell > fill), but from other posts, Create Color Schemes, Test Color Combinations - Colorspire will give the same result.
    Pick what colours you like, find the RGB, enter those numbers into Rewert (Red), Gruenwert (Green) and Blauwert (you guessed it, Blue)
    My favourite colour is Maroon, so R, G, B is 144, 24, 28, but need to lighten the colour up a bit.
    I also have the below settings active, again, not sure if they need to be or not, but they work.
    Adaptations:
    Cold Boot MIB Unit
    Hold down left button for 10 seconds (or so)
    Wait for restart
    Reset Background Lighting Setting in MIB
    with MIB on, goto the below;
    Menu > Vehicle > Settings > Factory Reset > Background Lighting > Reset
    Then you can go into Menu > Vehicle > Settings > Background Lighting
    You should have 10 colours at the bottom to choose from, select a colour, and both the MIB and AID change to that colour. If not, there may be a 3 colour small box to the right at the bottom. This doesn't change the Interior Door Lights, as on mine, they are just white.
    I've seen a couple of people on all forums have dramas with this, so thought i'd try to figure it out. Some of this is lifted from other guys posts, zloybob (via NZ_GolfR), so thanks.
    I'm certainly no expert on all this stuff, but this is a cool tweak, and hope this helps.
    Thank you very much. Much appreciated. Will try this asap. Best wishes.
    VW Passat Variant Highline B8 2017
    VW up! Move up! 2014.
    Sep 2017
    AID colour- needed
    needed
    Ahh, thanks mate
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Dec 2017
    QLD Australia
    Found my balls all good lol
    Aug 2017
    Uk
    Quote Originally Posted by Blackpaladin67 View Post
    Do they bounce when you play with them
    Dec 2017
    QLD Australia
    Mostly....
