If that headlight warning thing annoys you, that can be turned off to
Int. light, 2nd generation: weicher Farbwechsel: active
soft colour change-not needed
Int. light, 2nd generation: Instrumententafelbeleuchtung mehrfarbig: active
AID colour- needed
Int. light, 2nd generation: Mittelkonsolenbeleuchtung mehrfarbig: active
center console colour-not needed
Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed
needed
Interior light, light configuration: Mittelkonsolenbeleuchtung: installed
again Center console- not needed
Interior light, light configuration: LIN-Dachkonsole lokal aktivierbar: active
roof consol- not needed
Interior light, light configuration: Ambientemenue mit globalem aus: active
gives you a off button in background lighting to switch off door and footwell lighting
Interior light, light configuration: Ambientemenue mit alle Zonen: active
Adds the “background lighting” buttons in settings- needed
Interior light, light configuration: Ambient_Farbliste_HMI: active
gives you the colour slider at bottom of background lighting screen- needed
Interior light, light configuration: Frei_Farbwahl_ueber_HMI: active
Turns off the brightness slider in the background settings screen, so not active if you wanna dim the footwell door lights
Now all i need is to get them all to flash and cycle thur the colour spectrums and i could turn my car into a disco LOL.... thanks guys.
Sent from my SM-G935F using Tapatalk
When you switch views the balls bounce
Found my balls all good lol
