Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: Arteon Ambient light & LED Colour change
    Dec 2017
    QLD Australia
    Thanks to the great work done here by other posters was able to now get 10 colour palette which covers my MIB,door and dash LEDs and cockpit..super cool!
    Sent from my SM-G935F using Tapatalk
    Dec 2017
    QLD Australia
    All done with an OBD11 along with 6 other necessary mods.
    Sep 2017
    They look cool on the inside
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Oct 2017
    Copenhagen, Denmark
    Is there a "best way" to get the 10 colours palette with VCDS? A total guidance?
    VW Passat Variant Highline B8 2017
    VW up! Move up! 2014.
    Sep 2017
    Quote Originally Posted by vwcaddy123 View Post
    Tweak: Colour Change in AID
    Vehicle: Passat B8 206TSI R-Line MY17 (AUS)
    Tweak completed with OBDEleven, should work with VCDS, but may be slightly different on newer cars (My18s)
    Not sure if all the below needs to be done, but these are the settings on my car and it works.
    Control unit: 5F Information Control Unit
    Adaptations:
    Car_Function_Adaptations_Gen2: menu_display_ambient_illumination: activated
    Car_Function_Adaptations_Gen2: menu_display_ambient_illumination_over_threshold_h igh: activated
    To get the cool dials in the AID
    Control unit: 17 Dash Board
    Adaptations:
    Display depiction: Version 3
    Tube_version: variant_4
    Control unit: 09 Central Electrics
    Adaptations:
    Ambientelicht Farbliste: Rotwert Farbe 1: 144
    Ambientelicht Farbliste: Gruenwert Farbe 1: 24
    Ambientelicht Farbliste: Blauwert Farbe 1: 28
    Change all colours up to 10, none can be R: 0, G: 0, B: 0 as none will work
    I got the numbers for RGB from MS Excel (format cell > fill), but from other posts, Create Color Schemes, Test Color Combinations - Colorspire will give the same result.
    Pick what colours you like, find the RGB, enter those numbers into Rewert (Red), Gruenwert (Green) and Blauwert (you guessed it, Blue)
    My favourite colour is Maroon, so R, G, B is 144, 24, 28, but need to lighten the colour up a bit.
    I also have the below settings active, again, not sure if they need to be or not, but they work.
    Adaptations:
    Int. light, 2nd generation: weicher Farbwechsel: active
    Int. light, 2nd generation: Instrumententafelbeleuchtung mehrfarbig: active
    Int. light, 2nd generation: Mittelkonsolenbeleuchtung mehrfarbig: active
    Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed
    Interior light, light configuration: Mittelkonsolenbeleuchtung: installed
    Interior light, light configuration: LIN-Dachkonsole lokal aktivierbar: active
    Interior light, light configuration: Ambientemenue mit globalem aus: active
    Interior light, light configuration: Ambientemenue mit alle Zonen: active
    Interior light, light configuration: Ambient_Farbliste_HMI: active
    Interior light, light configuration: Frei_Farbwahl_ueber_HMI: active
    Cold Boot MIB Unit
    Hold down left button for 10 seconds (or so)
    Wait for restart
    Reset Background Lighting Setting in MIB
    with MIB on, goto the below;
    Menu > Vehicle > Settings > Factory Reset > Background Lighting > Reset
    Then you can go into Menu > Vehicle > Settings > Background Lighting
    You should have 10 colours at the bottom to choose from, select a colour, and both the MIB and AID change to that colour. If not, there may be a 3 colour small box to the right at the bottom. This doesn't change the Interior Door Lights, as on mine, they are just white.
    I've seen a couple of people on all forums have dramas with this, so thought i'd try to figure it out. Some of this is lifted from other guys posts, zloybob (via NZ_GolfR), so thanks.
    I'm certainly no expert on all this stuff, but this is a cool tweak, and hope this helps.
    Dec 2017
    QLD Australia
    Quote Originally Posted by DR074 View Post
    Adaptations:
    Adaptations:
    Adaptations:
    Adaptations:
    Cold Boot MIB Unit
    Wait for restart
    Hi dr074 great post. I found a discussion on the forum where you jap and someone else posted and included the full colour spectrum numbers for each line. Thats where i got mine mod from. Can't find it now of course.
    Sep 2017
    Yeah, I couldn't find it either. I would have included the link
    Sep 2017
    Aug 2017
    Uk
    Rotwert Farbe 1:217
    Gruenwert Farbe 1:221
    Blauwert Farbe 1:235
    Rotwert Farbe 2:169
    Gruenwert Farbe 2:169
    Blauwert Farbe 2:169
    Rotwert Farbe 3:253
    Gruenwert Farbe 3:108
    Blauwert Farbe 3:55
    Rotwert Farbe 4:242
    Gruenwert Farbe 4:0
    Blauwert Farbe 4:40
    Rotwert Farbe 5:254
    Gruenwert Farbe 5:88
    Blauwert Farbe 5:240
    Rotwert Farbe 6:124
    Gruenwert Farbe 6:63
    Blauwert Farbe 6:190
    Rotwert Farbe 7:0
    Gruenwert Farbe 7:102
    Blauwert Farbe 7:255
    Rotwert Farbe 8:0
    Gruenwert Farbe 8:204
    Blauwert Farbe 8:255
    Rotwert Farbe 9:0
    Gruenwert Farbe 9:204
    Blauwert Farbe 9:0
    Rotwert Farbe 10:136
    Gruenwert Farbe 10:255
    Blauwert Farbe 10:57
    Pic of the colours
    Aug 2017
    Uk
    Display depiction gives you the bouncing dots in between the dials
    tube version gives you the dials (but you need the newest version of VCDS)
