Tweak: Colour Change in AID
Vehicle: Passat B8 206TSI R-Line MY17 (AUS)
Tweak completed with OBDEleven, should work with VCDS, but may be slightly different on newer cars (My18s)
Not sure if all the below needs to be done, but these are the settings on my car and it works.
Control unit: 5F Information Control Unit
Adaptations:
Car_Function_Adaptations_Gen2: menu_display_ambient_illumination: activated
Car_Function_Adaptations_Gen2: menu_display_ambient_illumination_over_threshold_h igh: activated
To get the cool dials in the AID
Control unit: 17 Dash Board
Adaptations:
Display depiction: Version 3
Tube_version: variant_4
Control unit: 09 Central Electrics
Adaptations:
Ambientelicht Farbliste: Rotwert Farbe 1: 144
Ambientelicht Farbliste: Gruenwert Farbe 1: 24
Ambientelicht Farbliste: Blauwert Farbe 1: 28
Change all colours up to 10, none can be R: 0, G: 0, B: 0 as none will work
I got the numbers for RGB from MS Excel (format cell > fill), but from other posts,
Create Color Schemes, Test Color Combinations - Colorspire will give the same result.
Pick what colours you like, find the RGB, enter those numbers into Rewert (Red), Gruenwert (Green) and Blauwert (you guessed it, Blue)
My favourite colour is Maroon, so R, G, B is 144, 24, 28, but need to lighten the colour up a bit.
I also have the below settings active, again, not sure if they need to be or not, but they work.
Adaptations:
Int. light, 2nd generation: weicher Farbwechsel: active
Int. light, 2nd generation: Instrumententafelbeleuchtung mehrfarbig: active
Int. light, 2nd generation: Mittelkonsolenbeleuchtung mehrfarbig: active
Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed
Interior light, light configuration: Mittelkonsolenbeleuchtung: installed
Interior light, light configuration: LIN-Dachkonsole lokal aktivierbar: active
Interior light, light configuration: Ambientemenue mit globalem aus: active
Interior light, light configuration: Ambientemenue mit alle Zonen: active
Interior light, light configuration: Ambient_Farbliste_HMI: active
Interior light, light configuration: Frei_Farbwahl_ueber_HMI: active
Cold Boot MIB Unit
Hold down left button for 10 seconds (or so)
Wait for restart
Reset Background Lighting Setting in MIB
with MIB on, goto the below;
Menu > Vehicle > Settings > Factory Reset > Background Lighting > Reset
Then you can go into Menu > Vehicle > Settings > Background Lighting
You should have 10 colours at the bottom to choose from, select a colour, and both the MIB and AID change to that colour. If not, there may be a 3 colour small box to the right at the bottom. This doesn't change the Interior Door Lights, as on mine, they are just white.
I've seen a couple of people on all forums have dramas with this, so thought i'd try to figure it out. Some of this is lifted from other guys posts, zloybob (via NZ_GolfR), so thanks.
I'm certainly no expert on all this stuff, but this is a cool tweak, and hope this helps.
