Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: APR tune feedback
    May 2019
    sydney
    APR tune feedback
    Hi All
    New here but was a mk6 R owner, i pick up my Arteon EOW and will be going stage 1.
    has anyone already gone down this path and can provide insight?
    Regards,
    Well i can provide 1st hand feedback of an APR tune on the same engine (although in a Mk7 Golf R) as a friend of mine owns one. Stock the car was brisk at best but felt restricted. After the stage 1 tune the car was genuinely much faster, i believe they quote around 60kw and 100nm gain over stock. He has now progressed onto the stage 2 tune (with intake and down pipe) and is basically at the safe limit of the stock turbo now.
    The increase in power was certainly noticeable from stock to stage 1. It goes from being a brisk car to genuinely being a quick car. The size of the turbo on the 206kw 2.0TSI engine has quite a bit of headroom available for power increases up to around the 300kw mark. Its a much larger turbo than the one fitted to the Mk6 R.
    May 2019
    sydney
    since the post i have reached out to a couple of dealers/tuners who have come back with a power figure of 283kw and 555nm.
    he went on to also tell me that the engine and drive line is the same as the MK7.5R.... plenty of headroom.
    might have to document a thread on the build.. seems like not a lot of documentation from a performance POV.
    cheers
    Quote Originally Posted by nickbeh View Post
    Yes it is the same engine/turbo and driveline as the Mk7 R.
    I guess most Arteon buyers are after the grown up luxury car aspect of the vehicle, not so much a modification aspect.
    May 2019
    Wetherill Park, NSW
    Please keep us notified. I’d love to see results of the stage 1 tune. I’m thinking of doing the same.
    May 2019
    sydney
    In the process of booking it in.. im going APR stage 1 as stated 283kw but numbers and dyno are one thing real world is another
    ive felt what it did to my mates 7.5 R, he has R600 intake and res-delete so she sounds real good and quiet the shove.
    has out run a few cars (C63s, Stock FL RS3 and Cayman GTS) and logged a 12.035 on 1/4.
    Dec 2010
    Don't just delete the middle resonator on the Arteon. Trust me. It'll sound pretty ordinary. You'll need to do more than that to get the exhaust sound you're after.
    See here: Arteon Exhaust Mods
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
    May 2019
    sydney
    thanks for the write up mate you're a champion!
    it appears it may be a case of throwing a proper cat back on to generate sound..?
    what i would like is a bit more pops and farts... the investigation continues for now.
    Dec 2010
    Yeah - go a proper cat-back, or change the 2 rear mufflers. You'd probably have a lot more success even leaving the middle resonator in, but changing the rear mufflers to straight through types (if you didn't want to go through the expense of a whole new cat-back system).
    My car: MY18 Arteon
    Aug 2018
    Can I ask, around how much does it cost to do a stage 1 tune?
