The tune may have an updated version since it was installed on that vehicle - hard to say unless an agent plugs-in and does a diagnosis.
I bought my 2018 second hand last year. Turns out the previous owner installed the APR Stage 1 engine & transmission tunes plus cat back res delete. (Hate the res delete but that's a matter of just getting it reinstalled.)
The transmission, in D, is not great. Absurdly slow to kick down, like 2-3 seconds - ie no quicker than when it's in Economy mode. Constant struggle to get it in the right gear, it's super laggy. In S it's nice & nippy but i don't like leaving it in S, it's far too aggressive for driving around town. Especially with the rest delete - I feel like a teenager in an Evo...
Does anyone know, is the APR transmission tune tunable?
Sent from my Pixel 6a using Tapatalk
The slow kick down does seem to be a global issue on the DSG with some models having better factory tunes than others.
As above, checking for an updated APR version is a good idea.
You can check out the many YouTube vids to 'reset' the DSG memory by holding the accelerator for 10-20 seconds before starting the car. Worth a try and won't affect the APR.
I have the RacingLine DSG and ECU tune and also have the same complaint.
Sports mode is great, but keeps the revs up around 2-3,000+ RPM, so is a bit revvy/aggressive to leave it in 'S' for everyday driving. But Normal ('D') is sluggish and slow to kick down. I'll often give the accelerator pedal a quick/deep jab to trick it to shift down (and to pre-spool the turbo a bit).
I'll try the DSG memory 'reset' and see if that helps it to relearn.
I tried the accelerator pedal 'reset today. Not sure if it has done anything, will know after driving it some more.
Looks like ODBEleven have a "Basic setting of transmission" app, which appears to do a reset.
There's also a "Calibration of synchro - points of Transmission" app.. not sure what that one does, but it seems a lot of people have issues with that app..
