Thank you Garry for well thought out comments.
My first VW was the MK6 Golf, (replacing a TC Commodore and TC Corolla.)
This had two problems affecting ease of driving (not reliability)
As a driver I had to learn;
1.0 Do not hesitate entering my garage. Narrow entrance with a raised entry lip caused car to stall if entry speed too low. Then pushing on the accelerator would cause a high speed entry. OK, so try careful nudge of accelerator? Result, DSG overheat and safety disengage.
2.0 Do NOT park facing down hill. This could create a sudden high speed exit in some car parks, with far less control than parking in
my garage. Careful modulating of accelerator and hand brake was required. (My current Passat has Auto Hold to prevent rolling backward prior to uphill start. Have not tried it reversing uphill, learned my lesson from the Golf)
I understand there are two basic versions of DSG used by VW. Dry clutch and oil filled clutch. I think my diesel Passat 6 speed is oil filled?
I have NO complaint with Passat DSG. My only indication is by watching display to see what gear is in operation. the gear changes are so smooth.
BUT I now have to make up my mind between 110TSI Tiguan with 6 speed DSG and 162TSI Tiguan with 7 speed DSG. (Or the laid back 147TDi diesel with more grunt), Compounding the situation, I seem to remember my MK6 Golf was 7 speed DSG
MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
