Sounds like brake "groan" usually a brake pad change fixes it. Mine does it from the front if I haven't driven it for while (more than week), it's been raining and there is surface rust on the rotors, only does it backing out of the driveway, then it stops and doesn't reappear until the next time I haven't driven it for while.
If your local dealer is saying there is no fix then that may mean the OE brake pads are the cause, aftermarket brake pads may cure it.
You could also try calling VW Australia Customer Support, just in case the dealer is spinning you a line.
Gary
