Results 1 to 10 of 12
Thread: Which is Cylinder 1?
    Nov 2007
    I have a 2019 AW Polo 1.0TSI 85kw with a misfire on cylinder 1 .... have a coilpack ready to go on, but which 1 is cylinder 1?
    Pacific Paradise QLD
    Well its usually the one at the front end or are you asking which is no 1 in the firing order Pull leads off 1 at a time and it will show up I thought
    Some good tech files to download via the links below for this 1.0TSI 3 cylinder engine if you don't have them already.
    Also refer to the image below (taken from the 2nd link on page 108 ) if thats of any help.
    Spark-ignition three-cylinder engine 1.0l TSI 85 kW series EA211 (eng.) Design and principle of operation. Self-study program 111 Skoda - SKODA Karoq - BRISKODA
    Скачивание файла -tsi-engine-1-0-chzd-chzb-chzc-dkrf-dkrc-dkld-chzj-dkra-dsha-repair-manual-eng.pdf
    Which is Cylinder 1?-2024-02-21-09_45_57-repair-manual-tsi-engine_-chzd-chzb-chzc-dkrf-dkrc-dkld-chzj-dkra-ds-jpg
    Nov 2007
    Thanks, I'll start there (on the left) replace and scan, and repeat if necessary on the other side if the error persists.
    Nov 2007
    So, some background on this misfire.
    Have a friend's Polo 85TSI with a misfire. Mechanic told friend its the coilpack. Friend was quoted $900 + labour to replace 3 coilpacks.
    I though the price was a bit rich and had 3 spare coilpacks (slightly older revision but still working) so could help friend out.
    VCDS scan says its Cylinder 1.
    Replaced the coilpack on cyl 1. Still a misfire.
    Repeat on 2 and 3, still a misfire.
    Replace all 3, still a misfire.
    Pulled the 3 sparkplugs out, all very worn and old (probably never been replaced), though the 1 from cyl 1 was slight worse than the other 2.
    Bought 3 new sparkplugs.
    Fitted the 3 new plugs and refitted the original coilpacks. No misfire ....
    Mechanic was doing a dodgy on my friend ...
    Bottom line, unless you do it yourself, pick your mechanic carefully, and do not use a generic mechanic (such as my friend did).
    Mornington Peninsula, VIC
    Wow that's crazy, and $900 seems worse than the dealer would be, a set of R8 coilpacks maybe?
    I saw a video recently when the car was a write-off because a mechanic said it needed an engine, it turns out it only had low compression because of a broken valve spring, fixed on the car without the head off.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Far out how annoyed would you be if you had paid $900 for 3x new spark plugs.........even if they are iridium they are $20 each or so?
    Quote Originally Posted by MIG View Post
    Humble mechanic? Working on that neglected Mk7 GTI?
    Bingo, that's the one!, good channel.
