Results 1 to 10 of 110
Thread: Stage 3+ Tiguan build
    May 2012
    Hi Guy,
    Who makes the wheel flares and where did you source them from,
    Definitely a lot better looking than the overly priced genuine ones.
    On another note will APR be looking at distributing / manufacturing some of the parts you are using or is this more of a personal build
    Hi Pickles, These are genuine / oem versions - there are two styles.
    I imported them from a friend in Germany - they cost me $680 landed (would have been cheaper a few months a go but we lost a lot of ground against the EURO).
    I have a spare set available for cars without the side park assist if anyone wants a set (exactly as pictured)
    May 2012
    Bugger, I have park assist otherwise I would have been interested
    Turbo installation is well underway. Made some specification changes along the way VWR mounts in place also.
    So which one did you end up going with?
    Now is a good time to replace that front sway bar.
    Just make sure you have enough clearance with the tail shaft when you do the install.... speaking from recent experience
    Tigger, thanks for the heads up - Already sorted & VWR mounts in the subframe as well!
    The mounts will probably help with keeping everything in place. My experience was that the cover on the tailshaft hit the sway bar under accelleration as everyhting is pretty tight under there. Makes an awful racket when it happens...
