Scirocco R Downpipe released
APR Australia is proud to announce our new Scirocco R downpipe:
This piece is now fitted to several Scirocco's around the country & has OE clearances & factory like fit.
http://www.goapr.com/includes/img/pr...6_downpipe.jpg
We are finalising the full RSC exhaust for the Scirocco as we speak, a test vehicle is already fitted with the full system in Victoria & the results have been fantastic. look for a release of the full system in the near future.
Guy, any performance increase figures available for just the downpipe with no change to cat-back? I couldn't find any on the goapr.com.au website. If a car is already flashed with APR reflash, does the APR code need to be modified and the car re-reflashed with the new code to suit the downpipe? (either to avoid codes or make the best of the additional flow).
Finally, if one has to run stock VW engine mapping code for a period of time for warranty purposes, will this downpipe cause any cat efficiency codes etc?
Thanks
On a stage 2 file we generally see around ~ 9 wkw on a Mainline dyno.
Your stage 1 file goes from stage 1 to stage 2+ - free of charge with the APR downpipe. You need this for the extra flow as well as to change the catalyst efficiency parameters.
Its a 200 cell cat, so it will run on stock software for a while with standard mapping, but there is no way to judge the time etc as it refers to a number of starts & other sensor conditions.
- You may not post replies
- You may not edit your posts
Forum Rules
